Activity Forums Apple Final Cut Pro Legacy “Log and Capture” menu item missing
  • “Log and Capture” menu item missing
    Posted by Anthony Rossello on March 8, 2010 at 9:09 pm
    I have a strange mystery – I’ve completely lost the Log and Capture option in my File menu.
    I have been capturing and editing on this system (FCP 6.0.6) for several months now (heavily) and today I sat down to do a last minute (client pressured, of course) capture of about 10 minutes of footage, hit command+8 and nothing happened. I went to the File menu and the Log and Capture item is simply no longer there.
    I did upgrade to a new RAID array and do some drive cleanup recently – is it possible that I corrupted a preference file somewhere?
    I can’t find anything anywhere online about this problem. Any ideas?
    Tony
    Anthony Rossello replied 16 years, 3 months ago 3 Members · 6 Replies
  • Jeremy Garchow
    March 8, 2010 at 9:35 pm
    What kind of drive clean up did you do? Have you tried trashing your prefs again?
    Jeremy
  • Anthony Rossello
    March 8, 2010 at 10:07 pm
    Clean up entailed consolidating drives, which is why I’m not clear on what I could have affected. I thought I was being pretty careful around the OS and apps drive.
    I did trash the com.apple.FinalCutPro.prefs file before posting and it didn’t help.
    Is there any way to figure out why that menu entry would disappear?
    I’m guessing a reinstall is in order but I’d really like to know what happened.
    T
  • Jeremy Garchow
    March 8, 2010 at 11:47 pm
    I’m really not sure what’s going on there, Tony. It is definitely very odd.
    A renistall should fix it.
  • Paul Hawke-williams
    March 9, 2010 at 5:24 pm
    Is your new RAID a firewire? I had a similar problem when I changed one of my FW drives. It had somehow stopped me suing the other FW port for capturing, once I unplugged the FW drive I could capture again with no problems.
    I suspect a FW problem with my hard drive, I ended up getting a refund, buying an alternative drive and all was fine but I can’t unfortunately remember what the model is of the one I took back – sorry!
    Try restarting the machine without the new drive if it is a RAID and see if your log and capture menu comes back.
    Hope this helps in some way
    Paul
    Paul Hawke-Williams
    http://www.macguruwales.co.uk
    Media Trainer – Mac Support – Video Production
  • Anthony Rossello
    April 1, 2010 at 8:36 pm
    Hey Paul,
    Thanks for the response. I’m finally back in the office after weeks of travel and, of course, in need of capturing. 🙂 The RAID array isn’t connected via Firewire, it’s eSATA. But, maybe the combination of the new striped RAID array and the FW connection from the camera is a similar situation?
    I’ll have to do some testing to see what’s going on.
    Thanks again,
    Tony
  • Anthony Rossello
    May 10, 2010 at 6:38 pm
    Just wrapping this up in case anyone comes across the thread w/ the same problem.
    Good news is a re-install fixed the problem.
    Unfortunately, I have no idea why the problem occurred in the first place.
    T
