Activity Forums Apple Final Cut Pro Legacy Log and Capture Mark In and Mark In not working
  • Log and Capture Mark In and Mark In not working
    Posted by Eric Strom on August 10, 2008 at 1:28 am
    I am trying to log and capture my footage but when I click on the Mark In or Mark Out button it still says Not Set. Is there a setting I need to change in order to make this work? I am importing with an HVX200 and have it set up to capture DV NTSC 48 kHz.
    Eric Strom replied 18 years, 1 month ago 2 Members · 3 Replies
  • Rafael Amador
    August 10, 2008 at 3:42 am
    After setting the IN and OUt, you need to click “log clip”.
    You will get a window to confirm. Just click YES.
    rafael
    http://www.nagavideo.com
  • Eric Strom
    August 10, 2008 at 5:17 am
    Right but the problem is that the Mark in and Mark out buttons are inactive and nothing happens when I click on them. So nothing will happen if I click on log clip because I cannot log clips. EVerything else works fine and I can capture the entire footage, just can’t log and capture individual clips
  • Eric Strom
    August 15, 2008 at 3:55 am
    Any ideas anybody?
