Activity Forums Apple Final Cut Pro Legacy Log and Capture issue with AVCHD: Only mix down stereo audio
  • Log and Capture issue with AVCHD: Only mix down stereo audio
    Posted by Mehmet Caglayan on August 30, 2009 at 5:59 pm
    Hi FCP users,
    I am trying to log and transfer some AVCHD files using AVCHD plugin. My options are P2 Plugin AVC-intra Apple ProRes 422 and AVCHD Plugin: Prores 422 and AC-3 Audio matrix stereo or plain stereo.
    When I transfer the clip it warns me that the audio will be mixed down to stereo. Which kills me. I had dual wireless on and I can’t separate them in the time line. When I try to move my levels both levels go up and down. If I try to delete one channel the other one is gone too.
    I checked the camera setting and the audio is not mixed. The wave form monitor shows two separate levels. What am I doing wrong?
    Mehmet Caglayan replied 16 years, 8 months ago 2 Members · 2 Replies
  • Chris Kennelly
    December 7, 2009 at 9:02 pm
    I just had the same issue, easy fix.
    In final cut pro:
    Modify>stereo pair (uncheck if this is checked)
    -c
  • Mehmet Caglayan
    December 9, 2009 at 3:26 am
    I new how to do it, but couldn’t remember. After I posted that question I remembered and fixed it.
    I do appreciate your post.
    Mehmet Caglayan
    Blue Voyage Productions
    Savannah, GA
