Activity › Forums › Apple Final Cut Pro Legacy › Log And Capture Frozen – But Audio Ok
  • Log And Capture Frozen – But Audio Ok
    Posted by David Rice on May 12, 2008 at 4:39 pm
    Hi Guys,
    System specs:
    G5 Dual 2ghz PPC
    2Gb RAM
    Tiger 10.4.11
    ATI 9600 Pro
    Kona2 5.1 Drivers
    FCP 6.0.3
    QT 7.4.5
    When I tried to capture, my log and capture window would play about 15frames, then lockup, and loop the 15frames over and over. So no video would be captured, but audio and TC came through no problem. I work at a post house, so our house ref is good, and we use lines to VTR so I know there isn’t a patching problem. Our setup has always proven successful. Also, I’ve proven that it’s not the VTR machine, since I’ve replicated the problem with different decks.
    I’ve reinstalled the kona drivers, uninstalling with the kona uninstaller. I’ve updated to the latest QT and FCP (this was happening with 6.0.2 as well). All in vain. The only fix I’ve found is that if I reset the PRAM and NVRAM, it works fine. But if I switch user accounts it fails to work, and I have to reset the system and reset the PRAM and NVRAM again.
    Any thoughts? Is there a PRAM and NVRAM test I can do?
    Thanks.
    -Dave
    Kevin Monahan replied 18 years, 4 months ago 2 Members · 3 Replies
