Activity › Forums › Adobe After Effects › locking off background and fading characters in and out
Posted by Alex Parker on May 2, 2006 at 7:57 amHi All,
IMichael Szalapski replied 20 years, 4 months ago 6 Members · 5 Replies -
David Eells
May 2, 2006 at 3:41 pmMy take on this is that the challenges are more along the lines of keeping the camera rock solid, keeping your lighting consistent, and controlling your shadows. If you do all that, the dissolving in and out is easy stuff. You could do it in After Effects, but it might be quicker and easier in an NLE.
Hope that helps.
Tristan Tumble
May 2, 2006 at 3:51 pmthe trick is, picking your background wisely.
if there are cars passing trough, and people, then eventough the cam is locked off, when you fade your people in and out, whatever is behind them at the time will fade with them (Cars/ppl/whatever)
so try the keep your background as clean as possible, an open field, a wall…stuff like that. -
Steve Roberts
May 2, 2006 at 3:57 pm… and shoot the visual equivalent of “room tone”: the background with nothing going on in front of it.
… and keep and eye on moving tree branches, garbage, birds, the location of the sun, and so on.
.. and be mindful of sound when you do these dissolves, if that’s applicable to your show.
Michael Szalapski
May 3, 2006 at 1:47 pmIf it’s in grass don’t forget the wind is gonna make a mess of the grass.
Oooh, also watch out for footprints/peopletrails in the grass/dirt/whatever.
Watch the sky for clouds.Dang, this isn’t gonna be as easy as it sounded.
So long as Mother Nature doesn’t mess with you too much it should be a lot of fun, you might try using masks along with keyframing the opacity to give a slightly more interesting look to the fades. You could also use fractal noise precomps as track mattes. For some bizarre reason I’m really liking this project, I wish I were doing it. So many ideas, so little time.
– The Great Szalam
(The ‘Great’ stands for ‘Not So Great)No trees were harmed in the creation of this message, but several thousand electrons were mildly inconvenienced.
