Activity › Forums › Maxon Cinema 4D › locking objects and layers
  • Lennart Wåhlin
    March 3, 2007 at 12:52 pm
    For layers in R10 you have the lock option in the layer manager (would be good to be able to right-click the layer sign directly in OM thou).
    Then you have the Protect Tag, it will only stop the object from being moved, you can still edit it.
    And then you can add a no-selectable coffee setup.
    I have a ready setup called GOGONONO at my site.
    https://www.tcastudios.com then go xfiles.
    There is a readme included that covers R9.6. The GOGO Tag is not yet optimized for R10 but NONO (the tag you are looking for)
    should work fine in R10.
    Cheers
    Lennart
  • Graeme Pereira
    March 4, 2007 at 3:53 am
    Great thanks for the info. I will have a look at the link.
    cheers
    g
