Activity Forums Adobe After Effects Locking distortion effects(ccsmear) to adjustment layer
  • Locking distortion effects(ccsmear) to adjustment layer
    Posted by Chris King on August 4, 2010 at 9:40 pm
    Hi is there anyway to lock an effect like ccsmear to a moving null object or adjustment layer?
    I’ve managed to get a null object to track a moving object in some footage, but now how do I get an effect like ccsmear to lock to the null object, so that the smear follows the moving object?
    I know this is a very basic question, but I can’t figure it out…..
    Chris
    Chris King replied 16 years, 1 month ago 2 Members · 3 Replies
  • Chris King
    August 5, 2010 at 7:44 am
    Hi.
    Yes smear needs a start and end point. My question is a fundamental one. I can make a null object or adjustment layer move relative to an object using tracking.
    Can I then make an effect such as ccsmear, set it’s position relative to, then parent it to that adjustment layer?
    If so, one could have a number of smears on one image, all moving with different parts of the image.
    Is there any way of doing this?
  • Matthew Keane
    August 5, 2010 at 10:27 am
    Sounds like this tutorial might be what you’re looking for (demonic face optional):
    https://library.creativecow.net/articles/kramer_andrew/Demon_Face_Warp.php
    Basically you track and stabilize the moving object you want to distort, then apply your effect, and then re-apply the tracking motion to animate the smeared footage over the original.
  • Chris King
    August 5, 2010 at 12:02 pm
    Yes I did see that tutorial, but it seems like an over complicated way of doing it. What if I want to do several smears on several tracked objects at once (like ten people) do I really have to go over the whole process 10 times? is there an easier way?
    Chris
