Activity › Forums › Apple Final Cut Pro Legacy › Lock part of sequence
Posted by Dustin Parsons on March 24, 2008 at 7:58 pmIs there a way to lock only part of your sequence in the timeline? I would like to be able to add new scenes to a sequence and not have the chance of accidentally messing up what I already have on there. Thanks
Jeff Pierce replied 18 years, 6 months ago 3 Members · 5 Replies -
Jeremy Garchow
March 24, 2008 at 8:12 pmYou can’t lock a part of a sequence, only whole tracks.
Jeremy
Jeremy Garchow
March 25, 2008 at 2:15 amYou can edit scene by scene in separate timelines, then add all the scenes to a master timeline in nests. Make sense?
Jeff Pierce
March 26, 2008 at 3:45 pmI have two methods for doing this:
1) Go vertical. If you’re working with 4 video tracks, and 4 audio tracks… lock those 8 tracks, and create your new work on video and audio tracks 5 and up.2) Duplicate. Make a duplicate of your timeline, and work from the duplicate. If something goes amiss, you can copy and paste from the original TL.
I use both methods all the time. I’ll get a project to an acceptable point of completion, but want to experiment with something. If the experiment turns out to be an improvement, great. If not, I’m no worse off.
Good luck.
