Activity › Forums › Maxon Cinema 4D › Lock object to position of a Mograph clone?
  • Lock object to position of a Mograph clone?
    Posted by Andy Stokes on October 10, 2008 at 1:54 pm
    Hi all,
    Is there a way to get the output position of a cloned object?
    I have animated some effectors to effect a small group of clones. Basically i’d like to be able to lock an object to the global position of a specific clone. Is this possible?
    I’m experimenting with the Matrix Object and Xpresso, but no luck yet.
    Andy
    Grant Salisbury replied 13 years, 3 months ago 3 Members · 4 Replies
  • Brian Jones
    October 10, 2008 at 9:46 pm
    Xpresso – Motion Graphics/Motion Objects/Data node
  • Andy Stokes
    October 11, 2008 at 12:57 am
    Hi Brian,
    Thanks once again. I managed to figure it out from your email and now have a working setup whereby I can Lock a null to a specific clone which can be selected thru the nulls userdata…
    I’m very new to Xpresso and really appreciate your pointers. I can see using expresso with MoGraph is openeing up even more possibilities.
    Cheers,
    Andy
  • Grant Salisbury
    May 29, 2013 at 7:27 pm
    Andy
    Could you share how you did this?
    Grant Salisbury
    Production Director
    http://www.gfxcreative.com
  • Grant Salisbury
    May 29, 2013 at 8:04 pm
    Actually figured it out. If anyone else reads this thread this is how we did it.
    We made a cloner and do whatever you want to it. Then add an xpresso tag and open up the editor.
    Drag in the cloner. Then make a new motion graphics>data node. Pipe the object parameter into the object parameter of the data node. Then pip the position of the data node into a null. Select the data node and in the attributes panel you can change what index number (which object in cloner) you want to use. The null will dynamically change when you change your index number.
    If this doesn’t make sense or someone needs more help just reach out, i can send you the file.
    grantsalisbury(at)gfxcreative.(com)
    Grant Salisbury
    Production Director
