Activity › Forums › Adobe Illustrator › Locating the center of radial gradient?
  • Locating the center of radial gradient?
    Posted by Dave Cook on August 3, 2015 at 6:39 pm
    I want to center a graphic over a radial gradient. How can I determine the X/Y coordinates of the center of the gradient and how can I align an object over this–either automatically (an align command?) or manually (duplicating X/Y coordinates?).
    Dave
    Illustrator CS5, Mac OS X 10.9.5
    Kalleheikki Kannisto replied 11 years, 1 month ago 2 Members · 1 Reply
  • Kalleheikki Kannisto
    August 19, 2015 at 5:33 pm
    If you’re not trying to get a mathematically perfect alignment, you can select the fill with the gradient tool, which shows the center point, put two guides to show the location then use the bounding bow of the graphic to align it to the guides.
