Activity Forums Adobe After Effects Locating the bottleneck on prerender slowdown?
  • Locating the bottleneck on prerender slowdown?
    Posted by Nick Drexler on August 20, 2019 at 8:14 pm
    Sometimes my prerenders get really slow, but my system monitors show I’m barely using my cpu, gpu, or ram. Its a brand new PC and my scratch drive is on a separate m.2 ssd. I am baffled. The effects I’ve been having trouble with are multiple instances of Turbulent Displace or Video Copilots Glass Eye. Is there some setting I’m missing?
    Ryzen 5 3600
    MSI X570-A PRO ATX AM4 Motherboard
    G.Skill Ripjaws V Series 32 GB (2 x 16 GB) DDR4-3200 Memory
    Asus GeForce GTX 1660 Ti 6 GB TUF OC Video Card
    Corsair CXM 550 W 80+ Bronze Certified Semi-modular ATX Power Supply
    Silicon Power 1 TB M.2-2280 NVME Solid State Drive (main ssd)
    Silicon Power A80 512 GB M.2-2280 NVME Solid State Drive (cache ssd)
    Nick Drexler replied 7 years ago 2 Members · 2 Replies
  • Tomas Bumbulevičius
    August 21, 2019 at 6:42 am
    Hey Nick, do you call pre-renders actual output files which you export for other use, OR actual preview lag in the viewport?
    One way or another, its not your systems setup. Feel free to share more information, specifically about your comp setup – resolution, assets used within effects, etc.
    Find out more:
    After Effects Tutorials: motion design, expressions, scripting.
    Boxer – Dynamic Text Boxes Template with a Live Preview
  • Nick Drexler
    August 21, 2019 at 10:59 pm
    Sorry I meant preview lag in the viewport. Like pressing spacebar.
    Example comp:
    30fps
    1080×1080 size
    10 layers of Video copilots Glass eyes
    no expressions
    no other assets
    the eyes are keyframed to move from the top of the screen to the bottom over 2 seconds. When I press spacebar the first play through is 8 seconds of a jerky animation.
    During preview task manager says my cpu is only at 28% load. My ryzen master monitor shows 1 core running at 3800mhz, but the other 6 are running 1-2k. This also makes me wonder why my cpu is not going to the full boost clock of 4.2ghz
    This animation only creates 500mb in the cache, so why is it so slow to preview?
    Is Glass Eye old and written inefficiently?
    if you want the free pluggin to try this:
    https://www.videocopilot.net/blog/2016/04/another-new-plug-in/
