Activity › Forums › Square Box CatDV › Locating lo res library references.
  • Locating lo res library references.
    Posted by Bruce Rawlings on December 26, 2013 at 9:28 am
    I have been using Catdv for a while and want to make a back up of the library. I cannot locate the folder with the material in it. Where is it located in relation to the program and what would it be called?
    Dave Clack replied 12 years, 9 months ago 2 Members · 1 Reply
  • Dave Clack
    January 2, 2014 at 10:35 am
    Hi Bruce, each asset in the CatDV database has a “media path” and “proxy file” that shows the location of the media and a lo res version.
    If you right click on an asset then you should have the options to “reveal in finder” or “reveal proxy in finder” too
    Hope that helps
    Dave
