Activity › Forums › VEGAS Pro › Loading project in Vegas7 20sec, in Vegas10 6min. Why?
  • Loading project in Vegas7 20sec, in Vegas10 6min. Why?
    Posted by Peter Groll on December 11, 2010 at 9:44 am
    Hi everybody
    I use Vegas 7, make project with 150 media in MJPEG AVI format (max 1 minute per media). Loading this project to Vegas 7 is max 20 sec.
    Now i trying Vegas 10, and load same project. This during 6 or more minutes. (before i clean audio peaks, after loading save project in vegas10 format)
    Sometime freeze. I thy some trick from this forum: ctrl + shift starting Vegas 10 rest cached settings. This help when start freezing. But always is loading 6-7 min.
    I try find at internet and this forum some solution. But not succesfull.
    Where is difference? its not in codes, i try more that one, instal uinstall, clean windos instalation, windows XP and Windows 7 same problem.
    Pleas can somebody help me?
    Peter
    Slovakia
    Peter Groll replied 15 years, 9 months ago 2 Members · 2 Replies
  • Stephen Mann
    December 12, 2010 at 7:00 pm
    This is becoming a frequent complaint. One thing that seems to be common with slow loads is that the source is encoded with MJpeg. I haven’t seen this problem with DV (avi files) or HDV (m2t files).
    Could Vegas be recoding the MJpeg file during the load?
    Steve Mann
    MannMade Digital Video
    http://www.mmdv.com
  • Peter Groll
    December 13, 2010 at 9:38 pm
    Thaks for answer Stephen.
    Its true other formats are very quick loded to vegas10, and work with fullHD video ist smooter like in Vegas7.
    But this problem with mjpeg avi its like some bug in Vegas10.
    Vegas dont recode the MJpeg file during the load, CPU is 5percent.
    I dont know what is Vegas doin durin loading. I use sysinternals process monitor that capture every disk an registry event during load. Vegas7 read one file (avi mjpeg) on 200 events in process monitor Vegas10 1500.
    Ithing its bug.
    And crash 3 times per hour if i edit mjpeg. AVC crash one per day.
