Activity Forums Apple Final Cut Pro Legacy Loading AVCHD to FCP 6.04
  • Loading AVCHD to FCP 6.04
    Posted by Michael Belanger on May 16, 2010 at 3:43 am
    In about 80% of the times I load from my compact Vixia HFS 100 camcorder I have the log and transfer do the beach ball and crash FCP.
    Is there a more reliable way of getting this material into FCP
    Currently using 6.04 and not using Snowy OS.
    Intel dual quad 3 ghz mac pro
    How hard can this be???
    John Fishback
    replied 16 years, 4 months ago
    4 Members · 6 Replies
  • Jerry Hofmann
    May 16, 2010 at 2:04 pm
    Try copying the files from the camera to a hard drive first.
    Jerry
    Apple Certified Trainer, Producer, Writer, Director Editor, Gun for Hire and other things. I ski.
    8-Core 3.0 Intel Mac Pro, Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D, AJA Io HD, 17″ MBP, Matrox MXO2 with MAX Cinema Displays
  • Joseph Holder
    May 16, 2010 at 3:22 pm
    there was a problem with log and transfer that makes it crash, and it was that you had to turn airport off, and it worked fine, so try that
  • Michael Belanger
    May 16, 2010 at 3:36 pm
    Thanks DID try and move entire disk to a hard drive but whenever I engage the L&T it beach balls.
    Also tried in iMovie but no love… Strangley it has worked with certain disks but seems to work only ONCE. The next time I put in the disk it beach balls. Of course never an issue with any other tapeless format I use… guess those are just more professional SxS and XDCAM HD and P2 never an issue/
    Is there an outboard transcoder that can make the files Pro Rez just like FCP??
    Mike B
    Dandelion Picture and Sound’
    dandelionediting.com
  • Jerry Hofmann
    May 16, 2010 at 8:27 pm
    My guts say your problem lies in a unclean installation…
    But try trashing preference files for FCP before you do anything more drastic. This isn’t a bug you’re experiencing, or we’d all know about it.
    Jerry
  • Michael Belanger
    May 16, 2010 at 9:10 pm
    Did the trash of prefs before no luck…
    Not sure about a clean install on OS but FCP might not be. I can try on my laptop which only has FCP and original os with a few updates. Very hard to believe that this is the result of installs done but a couple years ago.
    mike b
  • John Fishback
    May 16, 2010 at 10:43 pm
    Checkout ClipWrap. You might also run DiskWarrior. If your directory is corrupt that could affect L&T’s ability to find the data, thereby, causing the crash.
    John
    MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.8 QT7.6.4 Kona 3 Dual Cinema 23 ATI Radeon HD 3870, 24″ TV-Logic Monitor, ATTO ExpressSAS R380 RAID Adapter, PDE enclosure with 8-drive 6TB RAID 5
    FCS 3 (FCP 7.0.2, Motion 4.0.2, Comp 3.5.2, DVDSP 4.2.2, Color 1.5.2)
