Activity Forums Avid Media Composer Load sequence in bin, in to source monitor key command
  • Load sequence in bin, in to source monitor key command
    Posted by Jimmy See on March 7, 2018 at 6:58 am
    I’m often working with sequences of clips, rather than individual clips. Especially with interviews. I like to use the keyboard in favour of the mouse, when possible and when faster.
    I can currently select in to out from a clip in source monitor, lay it in to the timeline, and select a different clip in a different bin and do the same again, all using keyboard alone. However if I’m working with sequences, this falls apart because, though I can select the clip in the bin using the keyboard, the small enter key which on pressing would normally load a clip in to the source monitor, loads a sequence in to the record timeline. That makes sense because most of the time that’s what you’d want when selecting sequences in a bin, however, I wonder if there’s a separate, load in to source monitor command that I can assign to a key so that there’s no ambiguity which action will result.
    Jimmy See replied 8 years, 6 months ago 1 Member · 0 Replies
  • 0 Replies
