Activity Forums Apple Final Cut Pro Legacy lo res comp stills to hi res stills
  • lo res comp stills to hi res stills
    Posted by Andrea Stewart on May 4, 2010 at 5:22 pm
    Is there an easy way to get the same move that you put on your comp still on the hi res still when you replace it?
    If I copy and paste attributes the still blows up huge because its such a larger file.
    Andrea Stewart
    Producer/Editor/Director – Owner
    Germane Creative LLC
    Andrea Stewart replied 16 years, 4 months ago 2 Members · 2 Replies
  • Shane Ross
    May 4, 2010 at 5:34 pm
    Nope…gotta redo. This is what can take me DAYS to do. depending on how many stills I have. And this is why now I will be using ProRes PROXY as the offline codec that we use. Because using DV, then going to HD, means a LOT of time redoing moves on stills.
    Shane
  • Andrea Stewart
    May 4, 2010 at 6:08 pm
    Well that stinks. I was hoping it would scale the effect.
    Perhaps I’ll send to Motion and see if it works any better that way. I hate the back and forth between AE and FCP — its just a pain.
    Andrea Stewart
