Activity › Forums › Apple Final Cut Pro Legacy › Living with ProRes
Living with ProRes
Posted by Sergio Deustua on June 15, 2007 at 9:40 amSo,
what do you think is the best workflow method if you mant to work with ProRes, capture from the Panasonic HD1200A deck having a Blacmagick Decklink?Crlvideo replied 19 years, 3 months ago 8 Members · 12 Replies -
Walter Biscardi
June 15, 2007 at 1:23 pmIf you have a Mac Pro you can test capturing to the ProRes codec. Or you can capture native DVCPro HD and edit in a ProRes timeline.
If you have a G5 you might be able to capture DVCPro HD and then edit in a ProRes timeline, though I’ve heard some issues with that workflow too.
Walter Biscardi, Jr.
HD Editorial & Animation for Broadcast and independent productions.All Things Apple Podcast! https://cowcast.creativecow.net/all_things_apple/index.html
Read my blog! https://blogs.creativecow.net/WalterBiscardi
Russell Lasson
June 15, 2007 at 2:06 pm[walter biscardi] “If you have a G5 you might be able to capture DVCPro HD and then edit in a ProRes timeline, though I’ve heard some issues with that workflow too.”
Or you could just change the timeline from DVCPRO to ProRes when you finish, but I really depends on how you’re going to finish (tape, DVD, web, cell phone cinema…)
-Russ
Sergio Deustua
June 15, 2007 at 2:46 pmMy intentsions are to finish on tape an dvd.
Whay is this important in this issue? -
Sergio Deustua
June 15, 2007 at 3:06 pmMaybe a stupid question, but, is it posible some way to capture in prores via firewire?
Tom Wolsky
June 15, 2007 at 3:11 pmYou can with IoHD and a FW800 connection.
All the best,
Tom
Author: “Final Cut Pro 5 Editing Essentials” and “Final Cut Express 2 Editing Workshop” Class on Demand “Complete Training for FCP5” and “Final Cut Express Made Easy” DVDs
Shane Ross
June 15, 2007 at 3:18 pm[Langosta] “Maybe a stupid question, but, is it posible some way to capture in prores via firewire?”
Not directly from camera to computer. As Tom said, with the I/O HD, yes. But so far that is the ONLY firewire device that allows you to do that….and it isn’t even out yet.
You’ll need a MacPro and a capture card to capture ProRes422.
Shane
Littlefrog Post
http://www.lfhd.net -
David Roth weiss
June 15, 2007 at 4:19 pm[Langosta] “Maybe a stupid question, but, is it posible some way to capture in prores via firewire?”
Think of it this way:
Direct capture via firewire or SDI typically involves simply moving a data stream from a tape source to a computer hard drive.
Capture via a capture card (“digitizing”) enables on the fly conversion to another format or codec as its written to hard drive.
David Roth Weiss
Director/Editor/Post-production Supervisor
David Weiss Productions, Inc.
Los Angeles -
Russell Lasson
June 15, 2007 at 4:48 pm[Langosta] “My intentsions are to finish on tape an dvd.
Whay is this important in this issue?”If you’re finishing on tape, only certain systems can handle outputting ProRes in realtime. If you’re finishing to DVD, then it’s just moving data and file playback isn’t a big deal. You could even export to uncompressed if you hand the room.
-Russ
David Roth weiss
June 15, 2007 at 4:54 pm[Russell Lasson] “You could even export to uncompressed if you hand the room.”
But who would hand the room to?
That requires some really big hands…
David Roth Weiss
Los Angeles -
Russell Lasson
June 15, 2007 at 9:28 pm🙂 I guess I need to read my typing a little closer:)
-Russ
P.S. Could you hand me that room over there too?
