Activity Forums Apple Final Cut Pro Legacy Livetype on HD timeline
  • Livetype on HD timeline
    Posted by Greg Ball on June 28, 2008 at 3:36 am
    I’m editing a show on HD from an EX1, and I need to out put it as a full frame SD project on Digibeta. The client does not want it letterboxed.
    Everything works well and looks great! My only issue is that I need to create a few lists of text with will be on the right side of the frame while I have boxes of video clips on the left side.
    Since converting this sequence to full frame SD requires resizing the video 50% How would you handles livetype like this? Do I wait until I’ve created my SD timeline and do the graphics work there? Or do I create this in the HD timeline? I also have a Logo that was delivered to me as a PSD file. How do I work with that?
    Thanks for your help.
    Dan Riley replied 18 years, 2 months ago 5 Members · 13 Replies
  • 13 Replies
  • David Roth weiss
    June 28, 2008 at 4:07 am
    Greg,
    Cut and paste your video to a 8-bit uncompressed SD timeline, resize and position the video properly in it’s final position, then do your titles. Otherwise, I can assure you will wind up doing all the titles twice. There’s nothing like working with the final product right in front of you.
    David
    David Roth Weiss
    Director/Editor
    David Weiss Productions, Inc.
    Los Angeles
    A forum host of Creative COW’s Apple Final Cut Pro, Business & Marketing, and Indie Film & Documentary forums.
  • Dan Riley
    June 28, 2008 at 5:23 am
    um. excuse me, but you certainly don’t need to create a new timeline for
    output to SD. Do you use a KONA 3 card? You simply have the secondary
    output be centercut SD out SDI to your digibeta which is exactly what we do.
    I cut the DVCPRO HD 720p 23.98 sequence, using an HD monitor while editing,
    with the monitor set to show me safe title for SD or I just watch the show on the
    Sony monitor right next to the HD monitor.
    All you need to do with livetype is make sure the stuff ends up in safe title.
    Dan
  • David Roth weiss
    June 28, 2008 at 5:43 am
    Dan,
    Sure, there are lot’s of ways to skin a cat. And maybe Greg has a Kona card, though he didn’t mention it.
    But you know, your “um excuse me” crap is really uncalled for and simply very disrespectful. It’s Friday night fella, so mellow out dude.
    David
    David Roth Weiss
    Director/Editor
    Los Angeles
  • Greg Ball
    June 28, 2008 at 12:38 pm
    Thanks. I actually have a LHe card. But I’m leaning toward what you’re suggesting David. Basically I’m editing it on my home system and then moving it to another system at a client facility to output the Digibeta. Both systems are identical.
    With that in mind, if I’m using the same external drive, do I only need to move the project file onto that external drive and plug it into the the client’s system to output my sequence? Any catches? Thanks.
  • Chris Poisson
    June 28, 2008 at 1:05 pm
    I COMPLETELY agree with David. Dan, that was very rude. Plus assuming the poor guy has a $2500 card is a really arrogant presumption, as though you were saying, “What stupid, you don’t have a Kona card?” You owe him an apology.
    Have a wonderful day.
  • Chris Poisson
    June 28, 2008 at 3:08 pm
    I meant to add, I also agree with David’s workflow recommendation, even though I DO own a Kona card, because I can zoom, pan and tilt with 1080 material in and SD timeline, and work on the same projects at work where I DON’T have a Kona card.
  • Dan Riley
    June 29, 2008 at 3:27 pm
    Well I guess I pissed everyone off. Didn’t mean too. Sorry, I apologize.
    In my experience you don’t need to make a separate sequence when
    outputting to DigiBeta from a DVCPROHD 23.98 sequence when
    using a Kona3 Card. That was what I should have said, without the
    commentary I guess.
    Dan
  • David Roth weiss
    June 29, 2008 at 3:36 pm
    [Dan Riley] “Sorry, I apologize.”
    No problem Dan!!! I’m really glad you did that, it’s so, so rare these days.
    BTW, as I said before, there are many ways to skin a cat, and you’re right it’s not necessary to move to an SD timeline. But, given the complexity of Greg’s titling scheme and the flexibility in terms of resizing and repositioning HD video on the SD timeline, I think it’s a good choice.
    In any case, let’s get back to saving the world now.
    THNX for responding…
    David
    David Roth Weiss
    Director/Editor
    Los Angeles
  • Dan Riley
    June 29, 2008 at 3:49 pm
    While we’re on the Livetype subject, have you noticed since FCP 6.0.2,
    if you have a title with a background (like type setting on a color bar or something)
    you must render the title before importing to FCP? Previously all you had to do
    was import the livetype file. If you don’t render, the livetype background doesn’t
    key correctly, like the alpha isn’t being seen by FCP.
    Dan
  • David Roth weiss
    June 29, 2008 at 4:00 pm
    [Dan Riley] “If you don’t render, the livetype background doesn’t
    key correctly, like the alpha isn’t being seen by FCP.”
    Feature set or bug? I suspect the later. In fact, I’d go way out on a limb and say definitely a bug. Seems like updates are almost always two steps forward, one step back at almost every turn.
    David Roth Weiss
    Director/Editor
    Los Angeles
