Activity Forums Apple Final Cut Pro Legacy LiveType looks awful IN FCP
  • LiveType looks awful IN FCP
    Posted by Scott Snyder on January 27, 2010 at 6:58 pm
    Hi everyone.
    When I create a Title in Livetype – it looks great in LT, it looks great when saved to desktop and played w/Quicktime.
    BUT when I drag it into FCP it looks terrible (all fuzzy and aliased) in the viewer and rendered in the Timeline. BUT when I export out my finished sequence, it looks fine in the final output.
    How do I get it to look normal INSIDE of FCP?
    scott
    Mitch Ives replied 16 years, 7 months ago 5 Members · 8 Replies
  • 8 Replies
  • Tom Wolsky
    January 27, 2010 at 7:21 pm
    Please provide the exact project properties of your LiveType project, and the exact item properties of the sequence you’re editing into.
    All the best,
    Tom
    Class on Demand DVDs “Complete Training for FCP7,” “Basic Training for FCS” and “Final Cut Express Made Easy”
  • Scott Snyder
    January 27, 2010 at 7:39 pm
    Hi Tom. I’m brand new to both LT and FCP, so please bear w me.
    LT Project Props: 720 x 486 / 29.97 Field Dom=none. Pixel aspect = .90 SMPTE Drop.
    I’m not sure what you mean by “item properties” of the sequence, but the “sequence settings” are:
    720×486 CCIR 601 NTSC 29.97
    Render 10-bit material in hi
    Is this the info you need? Remember, the LT titles don’t just look awful in Timeline, but in VIEWER as well. Thanks
    scott
  • Steve Eisen
    January 27, 2010 at 8:07 pm
    Another FAQ. Put your viewer to 100% or to properly view quality, look at it on an external NTSC/Pal monitor (TV set), with the proper hardware of course.
    Steve Eisen
    Eisen Video Productions
    Vice President
    Chicago Final Cut Pro Users Group
  • Mitch Ives
    January 27, 2010 at 8:20 pm
    I discovered this the day I installed FCS3. They said you could keep LT, which is true, but it’s no longer useful. Anything created in LT looks like crap in FCP7. It looks fine in previous versions of FCP. You can go into Motion and create the exact same title and it will look fine in FCP7. Go back and duplicate in LT and it looks terrible in FCP7. I’m surprised more people haven’t noticed and reported it.
    Mitch Ives
    Insight Productions Corp.
    mitch@insightproductions.com
    http://www.insightproductions.com
  • Scott Snyder
    January 27, 2010 at 8:50 pm
    Hmmm, very interesting Mitch. That is EXACTLY what I’m doing – using my old LiveType from FCS2 with my new Final Cut Pro from FCS3!
    So that’s it then – all LT titles will look bad in FC7?
    I haven’t even begun learning Motion yet…can everything that used to be done in LT now be done in Motion? Just as easily? I find LT to be a very very simple program to use, but Motion looks a bit daunting.
  • Tom Wolsky
    January 27, 2010 at 10:29 pm
    Try putting the LiveType project inside Motion and putting that into FCP.
    All the best,
    Tom
  • Kevin Monahan
    January 29, 2010 at 5:30 pm
    I had the same problem bringing Live Type files into a Final Cut 1080P Apple Pro Res sequence.
    This was our fix:
    LIve Type creates a Movie that uses the Animation CODEC. This looks fine on its own but when
    it is imported into Final Cut and rendered, the text looks Lo Res and jagged. If you first open the
    Live Type movies in the Quicktime Player and export them as Apple Pro Res (in our case since that
    is the compressor we are using) the resulting movie, when imported into Final Cut looks fine.
  • Mitch Ives
    January 30, 2010 at 12:32 am
    Ours was all P2 720p. Matched LT w/ FCP and still no joy…
    Might try some work-a-rounds based on your approach…
    Mitch Ives
