Activity › Forums › Adobe After Effects › Live update
  • Live update
    Posted by Dan Carr on February 26, 2014 at 8:55 pm
    Hello. I have two composition viewer windows open. One shows the main comp. One shows the comp nested in the main comp. The nested comp contains Element X”. I see “Element X” in both composition viewer windows.
    When I drag “Element X” in the nested comp, it updates live as I’m dragging. But the main comp doesn’t update “Element X” live. It waits until I release the mouse to update.
    Is there a way to have both comps update live as I drag “Element X”?
    Thank you.
    Roland R. kahlenberg replied 12 years, 6 months ago 2 Members · 5 Replies
  • Roland R. kahlenberg
    February 27, 2014 at 12:41 am
    [Dan Carr] “Is there a way to have both comps update live as I drag “Element X”?”
    Nope! The active comp will always be rendered first, then the second comp – the lag you experience is something you have to live with. You may want to look at soloing only pertinent layers when working with such a Workspace.
    HTH
    RoRK
    Latest AE Workshop – MoGraph Intensity – Shapes & Text
    Intensive mocha & AE Training in Singapore and Other Dangerous Locations
    Imagineer Systems (mocha) Certified Instructor
    & Adobe After Effects CS6 ACE/ACI
  • Dan Carr
    February 27, 2014 at 12:44 am
    I appreciate your time, and your succinct answer.
    Thanks.
    February 27, 2014 at 3:39 pm
    Dan, I should add that what you have alluded to; opening two related comps, side-by-side is a feature officially/commonly referred to as ETLAT (edit this, look at that). Also, Live Update has been removed from AE CC. In AE CC, the UI is driven natively by OpenGL – this is sufficiently fast without requiring the Live Update function. There is also redundancy for the Live Update feature in Fast Previews.
    HTH
    RoRK
  • Dan Carr
    February 28, 2014 at 3:06 pm
    Thank you for this information. I still get confused by the myriad processing/preview options in AE CC. I don’t see any mention of “Live Update” when I click the “Fast Previews” button below the comp window. I do see that “Live Update” is checked in the drop-down menu at the top-right of my timeline window.
    Please don’t feel obliged to clarify any of this, though. You’ve already been very helpful. I’m a grown-up, and should probably take some responsibility for doing my own reading. But damn, I read the guides, and I’m still confused. Then again, I’m very old…
    Thanks again for your responses. I appreciate your time.
    February 28, 2014 at 9:13 pm
    Good that you pointed out that Live Update still exists. I actually thought that it was removed entirely. And I agree that the number of preview options is quite staggering. I find them useful when working on either a basic Timeline or when the Timeline gets heavy. For basic stuff, set Fast Previews to Final or Adaptive. For heavy timelines, I alternate between Final, Adaptive and Fast Draft.
    HTH
    RoRK
