Activity Forums Adobe Illustrator Live Trace Invert Black and White
  • Live Trace Invert Black and White
    Posted by Paul Kennedy on March 28, 2009 at 9:08 pm
    I’m working on a mostly black and white animation and using live trace on images in Illustrator before I start to animate them.
    I was hoping to know if there was anyway to invert the black and white after running a live trace on an image, without tediously doing by hand using the Live Paint option?
    For example, I’m doing one now of the Golden Gate Bridge, and by default when I live trace it, the bridge is turning out black while the sky and things is turning out white. I want the opposite to this.
    Paul Kennedy replied 17 years, 5 months ago 3 Members · 5 Replies
  • Ronaldo Montalvo
    March 31, 2009 at 5:48 pm
    maybe try exporting the pallette swatches when you make the trace. there should be just the 2 used colors swatches of black and white. double clik the black swatch and change it globally to white and globally change the white to black.
  • Vincent Rosati
    April 4, 2009 at 10:52 pm
    There used to be an invert-color option. Now the ‘Recolor Object’ option is available when you select vector objects, It’s a greyed-out color wheel on the menu.
    I haven’t used it, so I can’t say more.
    This function looks like it might be actionable, in case you need to batch process.
    Just some ideas.
    Vince
  • Paul Kennedy
    April 5, 2009 at 6:31 pm
    I’ve found the recolor object button, but changing any options doesn’t seem to have any effect.
    As for exporting the swatches before I live trace, how would I go about that?
    In the meantime I’ve been using the live paint option and through sheer randomness I’ve got some pretty successful results, but it is pretty random and I don’t want to be relying on it.
  • Ronaldo Montalvo
    April 6, 2009 at 6:55 pm
    under object/live trace/trace options, on the left side of the trace options tab there is a check box to export swatches. after you do the trace, double klik the black swatch it exported and globally change its color to what you want.
  • Paul Kennedy
    April 6, 2009 at 7:47 pm
    Hey, thanks a million, that worked perfectly.
