Activity Forums Panasonic Cameras Live capturing HD footage from HVX to FCP
  • Live capturing HD footage from HVX to FCP
    Posted by Chen Chan on April 26, 2008 at 3:36 pm
    Hey,
    I was wondering if it were possible to live-capture 1080 or 720 footage via firewire straight from the HVX into Final Cut?
    i know it’s doable in standard def, but hd i’m not so sure of…
    -Tinx
    Bob O’brien replied 18 years, 3 months ago 3 Members · 8 Replies
  • 8 Replies
  • Nate Stephens
    April 26, 2008 at 6:44 pm
    Tinx,
    It works great.. 1080 Firewire (32feet) to Mac Book Pro with Capture Now – Final Cut Pro to xpress card sata mirrored raid… Over 2+ hours and NO drop outs or other problems..
    When you consider the cost of P2 cards and if you don’t mind being tethered to a computer, it is almost cheaper…. this way..
  • Chen Chan
    April 28, 2008 at 4:13 pm
    Thanks Nate.
  • Bob O’brien
    May 20, 2008 at 12:03 pm
    Nate,
    When outputting HD over firewire to MacBook Pro (fcp), can you also record SD to miniDV at the same time?
    Thanks.
    Bob
    *DualG5, 2gHz, w/5.1.4 firmware
    *2.5 Mb RAM, 160 Mb SATA HD
    *UL4D w/1.4.0f1 flash and 3.0.0 driver *HMV800 DualMax RAID0 Revision 511
    *AJA IO w/20-21 firmware & v1.1r1 driver
    *OSX10.3.2, QT 6.5, FCP 4.1.1, Livetype 1.1.1, Soundtrack 1.1, DVD
  • Chen Chan
    May 20, 2008 at 12:26 pm
    Nope.
    When live capturing HD, you can’t record to miniDV at the same time.
    However, I’m pretty sure for live capturing SD– you can capture miniDV.
  • Nate Stephens
    May 20, 2008 at 2:00 pm
    Bob,
    You need to ask Shane, our MXO specialist…. but I am pretty sure the Matrox MXO which you would plug into the DVi monitor port does real time HD to SD conversion. That MXO SD you could plug into a DV deck….
    Good question
  • Bob O’brien
    May 20, 2008 at 3:21 pm
    Great idea. Since I do have an MXO, that sounds like a winner. I’ll test it out.
    Bob
  • Nate Stephens
    May 20, 2008 at 3:27 pm
    Bob,
    Since you have the MXO, how do you like it? How do you use it in your workflow?
    Do you have the Matrox Dual or Triple head adaptors also?
    I am updating my edit suite to the new Mac pro,, and Have been debating the value of the MXO..
  • Bob O’brien
    May 20, 2008 at 3:35 pm
    I use it for monitoring HD on a 23″ Apple display while editing on my MacBook Pro. I use two LaCie eSATA drives attached to the MBP via an Expresscard adapter. It works great.
    I really have not had the need to use the MXO in any other way yet, but am aware of its functionality as a downconverter. I’ll give it a try.
    Thanks again.
    Bob
