Activity › Forums › AJA Video Systems › Live Capture w/ TC through a Deck
  • Live Capture w/ TC through a Deck
    Posted by Michael Sacci on July 24, 2008 at 12:12 am
    I’m trying to capture the program feed from a Multicam shoot. The feed that I’m getting is an HD-sdi signal but the TC is coming from a Deck via RS422. In FCP the only time I can get timecode to run is when the deck is in REC PAUSE, but when I try to do a capture now the capture aborts and gives me and end of tape message. Deck is in Local. When we put the deck in REMOTE it will not send TC. Device control in FCP is set to AJA IoHD 29.97 Sony VTR. I have access to Sony DBeta, 500, 2000 as well as HDCAM SR 5000 decks. (of course capture now works with non-controllable device but that is useless to me.)
    Then when I try to capture with the AJA VTR Xchange I cannot get it to record with the TC.
    I’m in a major studio so the deck and TC Generator are a room down the hall. They have no way to patch LTC TC.
    Does anyone know how to make the deck work with FCP. or what settings are needed for AJA VTR to read RS422 TC.
    Jeremy Garchow replied 18 years, 1 month ago 2 Members · 13 Replies
  • 13 Replies
  • Jeremy Garchow
    July 24, 2008 at 2:30 am
    In VTR Exchange, did you go in to the prefs and change it from ‘rp188 or ioHD LTC’ to ‘Deck’?
    Also, please be aware with embedded LTC, that VTR exchange will show -:–:–:– but after recording the tc will be in the file (play it back in vtr exchange). This will be fixed in an update. Also make sure that the deck is in fact sending embedded LTC in the menus.
    Jeremy
    I should add this will not work in FCP as FCP will cut off the tc when it’s put in non-controllable device. And as you have found out, it won’t work when it’s set to a deck control preset. It is a limitation of FCP at this point.
  • Michael Sacci
    July 24, 2008 at 3:19 am
    I did have the pref set to deck but I don’t have LTC connected, the studio is telling me that they cannot patch a straight BNC from deck to IoHD.
    So to confirm what will NOT work.
    -Capturing w/ TC in FCP when the deck is in REC Pause and VTR set to local.
    – AJA VTR exchange, TC is not available via RS422.
    Then follow up question, “embedded” LTC, do you mean within the SDI stream? or LTC out from deck to LTC in from deck.
  • Jeremy Garchow
    July 24, 2008 at 3:28 am
    [Michael Sacci] “Then follow up question, “embedded” LTC, do you mean within the SDI stream?”
    Yep. In that case, set the pref in vtr exchange to ‘rp188 or ltc’.
    JG
  • Michael Sacci
    July 24, 2008 at 3:33 am
    Jeremy, once again, thanks for your insight, I don’t think I tried that combo, I will when I get the studio tomorrow.
  • Jeremy Garchow
    July 24, 2008 at 3:49 am
    [Michael Sacci] “I will when I get the studio tomorrow.”
    Let me know how it goes. You must use VTR Exchange, though.
  • Michael Sacci
    July 24, 2008 at 4:37 pm
    Embedded TC working like a charm. Thanks.
  • Jeremy Garchow
    July 24, 2008 at 4:42 pm
    [Michael Sacci] “Embedded TC working like a charm. Thanks.”
    No worries. Nice ain’t it?
  • Michael Sacci
    July 28, 2008 at 3:29 am
    In the end it didn’t work, there must be something wrong with my laptop. Video kept glitching and all sort of weird things going on.
    I did a reinstall of the OS and I will test it again when I get the SR deck to capture all the tapes. But to be safe I think I may use the Kona3 for all the capture.
  • Jeremy Garchow
    August 2, 2008 at 4:56 am
    What laptop do you have and how much RAM?
  • Michael Sacci
    August 3, 2008 at 11:59 pm
    MBP 2.16GHz Core Duo with 2 GB of ram
