Activity › Forums › AJA Video Systems › Live Capture w/ TC through a Deck
  • Jeremy Garchow
    August 11, 2008 at 10:08 pm
    Yep. The recommended specs are the 2.33 Ghz and as much RAM as you can.
    From AJA.com:
    • MacBook Pro (2.33GHz Core 2 Duo minimum), 2GB or more of system RAM, ExpressCard/34 FireWire 800 card or ExpressCard/34 Sata Controller
    Good excuse to upgrade your system!
    Jeremy
  • Michael Sacci
    August 12, 2008 at 5:14 pm
    I know I cannot push this too hard, since it is out of spec but I think there is something wrong with the computer as a whole. Since the IoHD is doing most of the work and FCP can playback ProRes footage just fine and I just have the problem with capturing it.
    But I’m not pressed to upgrade so much that I cannot wait to see what comes out in Sept (hopefully).
  • Jeremy Garchow
    August 12, 2008 at 5:26 pm
    [Michael Sacci] “I know I cannot push this too hard, since it is out of spec but I think there is something wrong with the computer as a whole. Since the IoHD is doing most of the work and FCP can playback ProRes footage just fine and I just have the problem with capturing it. “
    It still takes a bit of power to oush that ProRes around for display on your mac. That MBP you have might not be a Core2Duo either, it might just be the coreduo. Supposedly that 2 makes a difference.
    I would wait until September too.
    Jeremy
Page 2 of 2
