Activity › Forums › AJA Video Systems › Live Capture w/ IoLD
  • Live Capture w/ IoLD
    Posted by David Peralta on March 7, 2007 at 1:16 am
    We have a studio setup and in order to speed up production times, we’re capturing straight to FCP via Firewire from our DSR-1800, but also recording to tape as a backup. The DSR-1800 is hooked up SDI-in to our SDI Switcher.
    What we want to do is capture via AJAio LD which is hooked up to a patch panel w/ SDI in from the DSR-1800, w/ RS-232 machine control, is there a way we can hook this up as well to have the switcher feed SDI into the AJAio while having timecode from the DSR-1800? and what else would i need to have that import?
    Thanks a lot guys!
    hmm… I wonder what this button does…
    Bob Zelin replied 19 years, 7 months ago 2 Members · 1 Reply
  • Bob Zelin
    March 7, 2007 at 4:04 am
    boy, are you confusing me with your questions !
    I use AJA and AVID products on a regular basis to capture directly to disk. There is no time code reference, especially one that matches an external VTR. Your switcher must have several SDI outputs – one can feed your I/O LD, and one can feed your DSR-1800 SDI input. If you only have one SDI output (hard to believe), you can get a very inexpensive SDI DA to distribute this signal (AJA makes one).
    Capturing direct from a live shoot, right into your edit system is a normal proceedure today.
    Bob Zelin
