Activity Forums Apple Final Cut Pro Legacy Live Capture into FCP
  • Live Capture into FCP
    Posted by Will Sanderson on April 14, 2011 at 3:34 pm
    Hi all,
    I have been using a switcher and Laird Media Converter connected to my Mac via firewire in order to capture live footage from our studios straight into FCP. The Laird recently died on me and as a work around, I have been capturing through the switcher, into a DV deck (where we record a backup tape), and out through a firewire connection into the mac.
    Since making this change, I’ve noticed a change in overall video quality (though we only record SD). So I have two questions. 1 – is this change in quality as a result of capturing from the deck? And 2 – is there a reason to replace the Laird Media converter or is there a better option to look into?
    Thanks as always for your help.
    Will
    Paul Dubbs replied 15 years, 2 months ago 3 Members · 2 Replies
  • Andy Mees
    April 15, 2011 at 7:08 am
    [Will Sanderson] “Since making this change, I’ve noticed a change in overall video quality (though we only record SD). So I have two questions. 1 – is this change in quality as a result of capturing from the deck? And 2 – is there a reason to replace the Laird Media converter or is there a better option to look into?
    1. Yes. It suggests that the SDI to DV conversion in the deck is not as clean as you were getting from the Laird convertor.
    2. Much better options, yes. The silver lining to this technical failure is that it presents a golden opportunity for you to ditch DV as your intermediate format, move to something better like ProRes 422. Have a look at the much more modern I/O options available these days from the likes of Matrox, AJA, Blackmagic and Motu. For example, a Blackmagic Design Decklink SDI card is only $295 and is possibly all you need. Or there are multi format portable options that allow SD/HD up, down and cross conversion, color corrected monitoring etc. The Matrox MXO2 LE, AJA IoExpress and Motu HDX-SDI are all sub $1000 portable I/O units worth checking out.
    Best
    Andy
  • Paul Dubbs
    July 12, 2011 at 5:35 am
    I know you mentioned you’re Laird died but when it WAS working, did it perform cuts properly? I have DV cameras and would like to make a live master without have to recut the entire project. I’m looking for a converter that would take for firewire DV signals and be able to cut a show from that.
