Activity › Forums › Adobe Premiere Pro › Little Help PLEASE
  • Little Help PLEASE
    Posted by Reggie Spires on February 2, 2008 at 5:53 pm
    Ok I shot a Basketball game in HDV 60i with the Canon XH-A1
    I then captured in adobe using that HDV preset for the project. Now I want to output it to a regular DVD. What do I change if anything in the export settings. I exported it changing nothing and it seemed to have some wavy lines.
    If I am not producing a HD DVD am I loosing anything shooting in HD and down converting. Should I not do that? I do want to keep the wide aspect.
    Please point me to a source that I can study to answer these questions or if anyone has time and can answer them I would appreciate it.
    Reggie
    Jon Barrie replied 18 years, 7 months ago 2 Members · 3 Replies
  • Jon Barrie
    February 3, 2008 at 12:47 am
    The waving look is probably the interlacing of the video. 60i means interlaced. there is a field odd and even and they are slightly delayed from one another, giving a wavy look. It’s normal. How does the DVD look on a TV?
    – jon 🙂
    How many editors does it take to change a light bulb?
  • Reggie Spires
    February 3, 2008 at 2:29 am
    That was on tv .. so at what stage do I deinterlace?
  • Jon Barrie
    February 3, 2008 at 2:53 am
    Don’t deinterlace, that will lose have the image info.
    The field dominance could be the wrong way around, odd first instead of even. You need to match the way the footage has been captured and edited in.
    I’d just use the same preset you used for export and switch the field order…
    – Jon 🙂
