Activity › Forums › Maxon Cinema 4D › Liquid Fill Emitter – particles won’t render as liquid
  • Liquid Fill Emitter – particles won’t render as liquid
    Posted by Brian Murphy on September 4, 2025 at 6:51 pm
    I’m new to the liquid/particle systems for C4D 2025. I can’t find anything in the way of tutorials or explanation on the Liquid Fill emitter –
    I am filling a cube with particles using the liquid fill emitter, that seems to work fine, creating a massive grid of tiny spheres to represent the particles within the boundaries of my cube. I then add a Liquify object. Next, if I add a liquid mesh object, my “liquid” still shows as a grid of spheres, even when I render. So basically, my particles are not turning to liquid. Any ideas? Thank you in advance.
    Kouraib Abdmalek replied 1 year ago 2 Members · 1 Reply
  • Kouraib Abdmalek
    September 5, 2025 at 9:41 am
    Hi Brian,
    I think the tutorial below will be useful to you, and you will find in his channel other videos about this new feature in cinema 4D.
    https://youtu.be/FmI2sllgqS8?feature=shared
