Activity Forums Cinematography Lipstick Cam with Wide-angle Lens Suggestions
  • Lipstick Cam with Wide-angle Lens Suggestions
    Posted by John Fishback on April 28, 2009 at 8:36 pm
    I’m budgeting for an industrial where I need a 2-shot of a passenger and driver in the front seats of a car. The camera can be mounted off to the passenger’s side and needs to be inside the car if at all possible. It should have a 16:9 aspect ratio and be standard def as the final will be a web video. Any ideas or recommendations?
    John
    MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.5 QT7.5.5 Kona 3 Dual Cinema 23 ATI Radeon HD 3870
    ATTO ExpressSAS R380 RAID Adapter, PDE Enclosure with 8-drive 6TB RAID 5
    24″ TV-Logic Monitor
    Final Cut Studio 2 (up to date)
    Pro Tools HD w SYNC IO, Yamaha DM1000, Millennia Media HV-3C, Neumann U87, Schoeps Mk41 mics, Genelec Monitors, PrimaLT ISDN
    John Fishback replied 17 years, 4 months ago 2 Members · 2 Replies
  • Mark Suszko
    April 29, 2009 at 12:46 am
    Sony has a brand new one, just came out in the past month or two I think, should fit your bill, it is HD but you can use that to give you room to add re-framing and pans and zooms in post as you downconvert to the SD final, this HD down to SD, IMO, for this kind of job is ideal.
    The review I read on it was glowing. We have an older Sony LS-1 that matched our betacams pretty closely, considering. It was and is a tremendously productive little camera for car work. In the time it took us to rig a full-blown hood mount for a conventional camera, the lipstick was able to get me five different POV shots using just a pad of foam rubber and some gaffer tape, from angles inside and outside the car that the bigger camera could never deliver. We got a variety of screw-on primes for it, a fisheye and a less distorting wide-angle, from a security camera company like Supercircuits ior similar.
  • John Fishback
    April 29, 2009 at 7:37 pm
    Thanks, Mark
    John
