Lip Sync
Posted by Gordon Nicol on September 15, 2006 at 11:50 pmI use Vegas primarily as an audio editor but, less frequently use for video editing as well. For the first time I tried to do a Looping session. In the past, lip-sync wasn’t important on working with mostly music video type of projects.
I may have my settings wrong but, when I preview a clip in the browser, everything’s in sync but, when I drag the clip onto the timeline and play, lip-sync is off unless I use “print to tape” which takes forever as it has to render. I did that once but, then when I tried to record a voiceover, it required rendering again !
Are there some basic video settings that may have got changed which would effect this?Thanks as usual for your help.
Gordon Nicol replied 20 years ago 5 Members · 13 Replies -
Peter Wright
September 16, 2006 at 6:38 amWhat format video are you working with?
Lots of factors can affect lip synch, including your machine’s specs.
In your case, you seem to be referring to “apparent lip synch” – if you know it’s ok after print to tape I wouldn’t worry too much – any time you want to check a passage, drag to create a loop and hit Shift/B for a quick Ram Render
Another thing you could try is reduce Preview quality – what setting are you using?
Peter Wright
Perth, Western Oz
http://www.allroundvision.com.au -
Gordon Nicol
September 16, 2006 at 6:27 pmThanks Peter,
I’m using a QuckTime movie. And it’s essential to see properly as the voice talent is trying to match the on-camera talent. So she has to see it accurately as we’re recording so we know that it’s totally in sync, not after we have recorded.
I’ve been using Auto Preview. -
Doug Graham
September 17, 2006 at 2:42 amI’m not sure you can do it…there’s going to be some lag between what’s on the screen and the audio being recorded.
But does it matter? As long as the talent is in sync with what she sees on the screen, you can always slip the recorded audio clip to sync to the video afterwards.
Regards,
Doug Graham -
Peter Wright
September 17, 2006 at 4:52 amIf you’re doing mainly audio work I assume your sound card has ASIO drivers, so perfect audio synch should be ok – it may be the extra time to process QT is causing a delay with video/audio synch, so I would render a DV avi to use whilst doing the synching.
Also, are you using loop regions to record – that way you can select a passage at a time and Vegas will keep adding new takes automatically till its perfect
Peter Wright
Perth, Western Oz
Gordon Nicol
September 17, 2006 at 5:20 amPeter,
Thanks for that suggestion. I’ll try that, converting to avi.
And yes, I was using the loop regions, recording many takes until perfect and then moving on.
Appreciate your thoughts all the way from Oz : )
I myself am all the way from bonnie Scotland, but live in Dallas, Texas.Gordon
Jerry Waters
September 18, 2006 at 12:10 amHey Gordon, Jerry Waters here. Haven’t seen you post before. We have to meet for coffee. I guess you are in DV. The problem in HDV is worse. I know that it is in sync even though it looks out but I sometimes prerender to check. Is rendering a small size file to sync to out of the question?
Gordon Nicol
September 18, 2006 at 4:43 amJerry,
Thanks for the suggestion. You must be in Dallas too?
Sure we could meet up and have some java. In fact, my studio is right above La Madeleine (French restaurant) on Lemmon Avenue, ideal place for a nice cuppa. -
Edward Troxel
September 18, 2006 at 2:02 pmRemember that the video preview goes out via firewire while the audio goes through your computer’s speakers. There is a setting in Options – Preferences – Preview Device tab that will let you adjust that sync. By default it is set to “4” but you can make it higher or lower as needed for your system. The default has always worked great for me.
Gordon Nicol
September 18, 2006 at 2:24 pmAhhhh ! Jerry,
I didn’t realiz it was you !
Yeas, Why don’t you come on by and visit?
I’d love to catch up and show you what I’ve been up to.
Grrrreat things are happening. And I’d like to tell you about another group I’ve been visiting with that has a very similar feeling to Father T’s group.
Here’s my number (214) 559 4288
