Activity › Forums › Apple Final Cut Pro › Lion released.
Lion released.
Posted by Jeremy Garchow on July 20, 2011 at 1:46 pmGrowl. Grumble. Eat meat. Sleep in the sun.
Lance Moody replied 15 years, 1 month ago 7 Members · 13 Replies -
Brendan Gibbons
July 20, 2011 at 1:55 pmIt will be interesting to see if the Lion file versioning feature will be any use as far as having a history of your Fcpx project file.
Cheers,
Brendan
David Eaks
July 20, 2011 at 3:02 pmSeems like we are unable to choose an install location, contrary to what I’ve read was possible from people with dev versions around the web. I clicked “Buy” and it just starts… Figured. Download canceled immediately.
I followed DRW’s “Ready to Rumble” guide and have a blank “Lion” partition, ready. I guess it will have to be an upgrade to Snow Leopard. Here it goes…
Jeremy Garchow
July 20, 2011 at 3:07 pm[David Eaks] “I followed DRW’s “Ready to Rumble” guide and have a blank “Lion” partition, ready. I guess it will have to be an upgrade to Snow Leopard. Here it goes…”
Yes, Snow Leopard must be installed. In DRWs case, you would clone your test Snow leopard partition to the blank Lion partition.
Check out step 2:
https://www.apple.com/macosx/how-to-buy/
Jeremy
David Eaks
July 20, 2011 at 3:33 pmCool, I left it blank instead of cloning in hopes of a true clean install but this new fangled “clean upgrade” will have to do.
John Pale
July 20, 2011 at 3:45 pmYou can download and quit the installer before it does anything.
You can burn the disc image to a bootable DVD or USB drive.
You don’t actually need Snow Leopard installed. You can install to a clean blank drive if you wish.https://www.macrumors.com/2011/07/18/make-an-os-x-lion-boot-disc/
I tried it with the GM and it works. Todays release is identical to the GM.
Lion does not unlock any secret super duper improvements to FCPX.
Steve Connor
July 20, 2011 at 3:54 pmUnless there is an upgrade to FCPX due soon!
Steve Connor
Adrenalin TelevisionHave you tried “Search Posts”? Enlightenment may be there.
Jeremy Garchow
July 20, 2011 at 3:55 pm[John Pale] “You can install to a clean blank drive if you wish. “
Nice one. I would think that you would be able to restore this disk image to a USB drive or whatever partition on a hard drive and get away from the DVD.
John Pale
July 20, 2011 at 5:15 pmhttps://subrosasoft.com/blog/2011/07/create-a-bootable-mac-os-x-10-7-lion-flash-drive/
Full Lion install from bootable USB flash drive.
Jeremy Garchow
July 20, 2011 at 5:25 pm[John Pale] “Full Lion install from bootable USB flash drive.”
Bingo.
Lance Moody
July 20, 2011 at 8:49 pmJust a quick note to say that, because I am between projects at home, I went ahead and upgraded, as I usually do.
No known issues. FCP X And 7 running on same partition. Got new drivers from Black Magic for FCP7, all is working there.
Not a big believer in the idea of 20 different partitions but if that works for you, fine.
While I do remember occasional issues with upgrading in the past, they are a distant memory.
I suspect that the time I have saved by not using a super cautious approach may outweigh the ultimate time lost due to the occasion of having to do a complete rebuild (which I was prepared to do if necessary but has never happened).Lance
