Activity Forums Adobe Premiere Pro Linking media in batches
  • Linking media in batches
    Posted by Victor Camacho guerrero on January 3, 2013 at 3:09 pm
    Hi hello,
    I got loads of projects from my former guy working in my job. The premiere projects are a mess. In after effects, the linking media works really well because link in batches, if you select something, it finds as well other files in that folder or related.
    The linking media in Premiere works one by one, which makes the process quite a hell.
    Is there any way to solve this or work faster?
    Many thanks
    Victor Camacho guerrero replied 13 years, 8 months ago 3 Members · 6 Replies
  • Ann Bens
    January 3, 2013 at 3:26 pm
    Select all the clips in the project window.
    Then right click on the first clip and link.
    Rest will follow if in the same folder.
    Adobe Certified Expert Premiere Pro CS6
    Adobe Community Professional
  • Victor Camacho guerrero
    January 3, 2013 at 3:37 pm
    Thanks Ann,
    it worked, but not totally straighforward. I guess I need to select only the media , if for example I press Ctrl+A to select all, this does not work well. Is this right?
    Another thing, I realized is when moving projects across the network and keeping the same structure in the folder, for example moving the root folder to another hard drive, sometimes the files are missing too. I imagine this is because the path are Global and not locally created . Is there any way to change this??
    Many thanks
  • Walter Soyka
    January 3, 2013 at 5:32 pm
    [Victor Camacho Guerrero] ” I imagine this is because the path are Global and not locally created . Is there any way to change this??”
    No.
    By chance, are you going cross-platform (Mac to PC, or PC to Mac), or if on Windows, are you perhaps going from a non-mapped server location to a local drive?
    This is a problem I’ve been doing a bit of side work on — perhaps you could contact me off-forum (see my profile)?
    Walter Soyka
    January 4, 2013 at 11:12 am
    Thanks a lot for your kindness Walter,
    actually this is the main problem I have. How can i contact off-forum??? do i need to add you as a friend when I see your profile to send you a message??
    Many thanks
  • Walter Soyka
    January 4, 2013 at 9:25 pm
    Victor, my email is in my COW profile [link].
    Walter Soyka
    January 7, 2013 at 10:38 am
    Hello Walter,
    I sent you a private email from victorcamachoguerrero@gmail.com
    many thanks!!!
