Activity Forums Adobe After Effects Expressions Linking effects parameter to Slider
  • Linking effects parameter to Slider
    Posted by Madli Man on December 28, 2012 at 5:11 pm
    Hi again,
    I have a few question, i have 8 beam effects on one layer. i would like to animate beam time after it complete one beam to another beam. Its like linking one control slider(0 to 100) to complete 8 beam one by one next.
    sorry for my English.
    Please help sir.
    Thank you
    Madli Man replied 13 years, 9 months ago 2 Members · 3 Replies
  • Dan Ebberts
    December 28, 2012 at 6:25 pm
    I’m not sure if this is what you’re after, but you could use an expression like this for the Beam’s Time parameter:
    s = effect(“Slider Control”)(“Slider”);
    numBeams = 8;
    myIdx = 1;
    range = 100/numBeams;
    myStart = (myIdx-1)*range;
    myEnd = myStart + range;
    linear(s,myStart,myEnd,0,100)
    For the second beam, you would change myIdx to 2, etc.
    I hope that helps.
    Dan
  • Madli Man
    December 28, 2012 at 6:47 pm
    Hi Mr Dan,
    Wah.. Thank you for solving my problem. this is the code im stuck in for years. today only resume it again. Im really appreciate it very much for code. it just i change it completion to 50%.
    Thanks Dan.
    madli
  • Madli Man
    December 29, 2012 at 2:00 pm
    Hi Dan,
    here is another one question. regarding indexing
    this layer named “line 27” have point X Y expression, there is another layer named “null 27 that i would like reffering to target point from Index +1 or – 1 from Null 27
    please help sir
    Thank you.
    Madliman
    here is my expression for “line 27” XY :
    currentNull = thisComp.layer("Null "+(thisLayer.name.substr(7,3))) // get Null name
    currentNull(index+1).toComp([0,0,0]) // get point from layer above
