Activity Forums Adobe After Effects linking child layer’s marker to parent layer’s keyframe?
  • linking child layer’s marker to parent layer’s keyframe?
    Posted by Will Gan on December 8, 2019 at 1:37 am
    Hi I have a null layer as a parent with all the keyframes set up, then a bunch of children linked to the parent, I wonder is there a way to set up several markers on the child, each marker is linked to each keyframe on the parent, so you can move the marker on the child to change the timing as if you move the keyframes on the parent (but in this case you only need to animate the parent) , if I made myself clear.
    so the setup would look like this:
    parent: ____key1____key2____key3___…
    child 1: ____marker1____marker2____marker3____…
    child 2: _______marker1___marker2__________marker3_____….
    Will Gan replied 6 years, 8 months ago 1 Member · 1 Reply
  • Will Gan
    December 14, 2019 at 2:41 am
    any help? I’m still puzzling.
