Activity Forums Apple Final Cut Pro Legacy Linking Audio to AF ProRes files for singel sub clips
  • Linking Audio to AF ProRes files for singel sub clips
    Posted by Sascha Engel on February 1, 2012 at 7:40 pm
    Hi Everybody,
    my problem is a bit complicate to explain, but I try my best:
    I recorded some dance shows, part of a festival.
    The audio of the pieces I recorded inside the camera (AF101) as reference and apart on my H4n ZOOM Audio recorder (4 Channels – 2 Stereo Mic & 2 Line in from the Mixer of the theatre).
    Now, I am editing a short trailer/doc of 10min about the festival.
    I have hours of dance shows, from which I will pick just short moments and parts (e.g. as inserts to interviews).
    If I record full shows, with 2 Cams it’s easy: I line up the external recorded sound, sync it and it’s just there throughout the editing. But in this case, I am make subclips from the good moments, which I will use then for the trailer. How do I get the Audio under that? My complicate way would be, to open a new Seq, put on each sequence a show, line up the right audio to it, link the audio to my video file and make the sub clips from that.
    Any faster way?
    Thanx a lot.
    Sascha
    Sascha Engel replied 14 years, 7 months ago 1 Member · 0 Replies
  • 0 Replies
