Activity Forums Apple Final Cut Pro Legacy Linking 2 audio clips with 1 video clip
  • Linking 2 audio clips with 1 video clip
    Posted by Alexandre Brandt on March 29, 2010 at 1:16 am
    Hello,
    I tried linking 2 audio clips (its the same clip originally but cut in 2 for syncing purpose) with 1 video clip, but FCP only let me to sync 1 of them. Is there a way to go around that without having to do an export of the 2 audio clips and make them into one clip ?
    Thanks for reading !
    motion images + storytelling = ?
    -> FILMMAKING !
    Andy Mees replied 16 years, 5 months ago 3 Members · 4 Replies
  • Robb Harriss
    March 29, 2010 at 1:44 am
    try first linking the clips to each other. I think you can select them and make the a “stereo pair” if worse comes to worse. Then link them to the video.
    Non-linear: all the time and nothing but.
  • Alexandre Brandt
    April 1, 2010 at 12:56 am
    The thing is that my 2 audio clips do not come in the same time: one after the other and so FCP only lets me link one of them to the video.
    -> FILMMAKING !
  • Robb Harriss
    April 1, 2010 at 1:26 am
    and you tried linking the two clips to each other first?
    Just curious. In the past on various systems one was able to link all sorts of unrelated code. That’s how we’d sync double system sound and multiple cameras/tapes.
  • Andy Mees
    April 1, 2010 at 6:04 am
    If the source files aren’t going anywhere then you can simply lay out your sources in a sequence and export a quick reference movie to use in their place.
