Activity › Forums › Adobe InDesign › Linked text boxes with different styles
  • Linked text boxes with different styles
    Posted by Eythor Arnason on October 30, 2009 at 1:34 pm
    Hi
    I have a problem that I can’t find a solution to. I have this text that I want to flow between multiply text boxes. Each box will have it´s own style. I
    I have tried to create couple of text boxes and each has it’s own Paragraph Style with different font sizes. When I paste the text all the boxes get the same style as in the first box. If I try to set an new style to an box it won´t change, unless I go into the box it self and change the font or size manually and that is something I am trying to avoid. Any tips?
    John Mensinger replied 16 years, 11 months ago 2 Members · 1 Reply
  • John Mensinger
    October 30, 2009 at 3:33 pm
    I may be wrong, but if I understand you correctly, what you’re trying to do is impossible. I’m reading that you want any text spilling over into frame 2 to take on Paragraph Style 2…automatically, (while text remaining in frame 1 retains Paragraph Style 1).
    A paragraph style is applied to text bracketed by paragraph marks, and I can’t find any way to affect it via a frame-break. I speculated that it might be doable by setting up separate object styles for the two frames, each of which specifies a separate respective paragraph style, but none of my experiments produced a working model.
    If you find a way, please do post it back here.
    John M:
    All of the vim with none of that annoying vigor.
