Activity Forums Adobe After Effects Expressions Link X-Scale to animated Y-Position
  • Link X-Scale to animated Y-Position
    Posted by Sebastian Ungrad on February 11, 2014 at 10:27 am
    Hi there,
    i have animated an object in 3D space only Y-Position with an expression. So it goes up and down. On a different layer, that is the shadow of the object, i’m looking for an expression that takes the Y-value and makes an even X-scaling. So the shadow gets an even width while the first object is moving up and down.
    Hope u know what i mean.
    Here’s the expression for the y-position.
    -52+Math.sin(time*effect("FREQUENCY")("Slider"))*effect("AMPLITUDE")("Slider")
    Jason Jantzen replied 11 years, 3 months ago 3 Members · 2 Replies
  • George Goodman
    February 11, 2014 at 9:48 pm
    Add this expression to your shadow layer
    I put in some arbitrary values here. Change those and also make sure to change the “MovingObject” to the name of the layer.
    ypos=thisComp.layer("MovingObject").transform.position[1];
    startY = 500;
    endY = 560;
    startScale = [140,100];
    endScale = [100,100];
    linear(ypos,startY,endY,startScale,endScale);
    “|_ (°_0) _|”
    Sincerely,
    George
  • Jason Jantzen
    February 17, 2015 at 1:28 am
    Thanks George! This is exactly what I needed 😀 I animated a bouncing thing in Newton and needed to animate the shadow’s scale according to hte bouncing Y position.
    Jason Jantzen
    vimeo.com/jasonj
