Activity › Forums › DSLR Video › Link video clip with audio track in PPro CS5.5???
  • Link video clip with audio track in PPro CS5.5???
    Posted by Clayton Nolen on December 10, 2011 at 3:31 pm
    Hello,
    I have interview footage from a Canon Rebel T2i that I am using in an HD project in PPro. For higher quality audio, I recorded to an H4n. I’ve successfully imported the H4n audio, synced it to the camera audio and deleted the camera audio. Now, say I remove the clip from the timeline, and later decide I want it back, I have to go through the whole syncing process again, right? Is there a way to link the audio from the H4n to the video clip so that I won’t have to do that?
    Any comments would help!!!!!
    David Speace replied 14 years, 9 months ago 3 Members · 2 Replies
  • Rob Manning
    December 11, 2011 at 9:48 am
    Hi Clayton, Mac or PC, you can use: https://www.singularsoftware.com/help/pluraleyes_pp/howto_pluraleyes_premiere.html
    Not certain about the newer Audition, since my PPro, came with sound booth but Adobe should have a solution for this, if not, then they SHOULD get a solution.
    Rob
  • David Speace
    December 13, 2011 at 4:46 pm
    On the PP5 timeline… give it a right click and you can link the audio and video together. But, what you should do is export the media… to a new file. Set the work area bar over the clip… then go to file, export, media and click on match sequence settings and then click export and you will have created a new file with the audio and video in sync and ready to go for later use. Make sure you have source range set to work area.
    Dave Speace
    Producer/Director/DP
    DZP Video
    Windows 7, 64 Bit, i7 8 Core, 16Gb Ram, GeForce 4800
