Activity › Forums › Adobe After Effects Expressions › link the position of a layer to a different comp layer..
  • link the position of a layer to a different comp layer..
    Posted by Scott Mccall on November 6, 2008 at 3:24 am
    thisComp.layer("point control").effect("Point Control")("Point")
    How do I link the position of a layer in one comp to the position of another layer in a different comp?
    currently I have this, which works fine since the layer is in the same comp…:
    thisComp.layer(“point control”).effect(“Point Control”)(“Point”)
    this just links the position to a point control layer I have. what i want to do is put the point control in a seperate comp so I can have different layers in various comps linking to the same point control layer..
    I know this is probably a stupid question, hehehe, but I am learning!
    thanks in advance!
    Murat Atasoy replied 10 years, 6 months ago 5 Members · 4 Replies
  • Eric Sanderson
    November 6, 2008 at 3:21 pm
    instead of starting the script with “thisComp”, try starting it with “comp(“name of comp”)”
  • Abie Silva
    April 2, 2015 at 5:50 pm
    This is exactly what I needed to learn for a current project & for many more to come; THANK YOU SO MUCH!!
  • Sabrina Hochmuth
    March 8, 2016 at 10:48 am
    Hello,
    is there a way to to not use a comp name but just reference to the previous comp (the parent in relative path).
    I read referencing to parent is not possible, but is it possible just saying like “one comp above this comp”? (Would be handy in case i rename my “parent comp”).
  • Murat Atasoy
    March 12, 2016 at 11:18 pm
    With this code you link layername to layername2 in the same comp
    app.project.item(1).layer("layername").parent = app.project.item(1).layer("layername2");
    not work for one comp to other comp’s layer to link 😉
    app.project.item(1).layer("first_comp_a_layer").parent = app.project.item(2).layer("second_comp_a_layer");
