Activity Forums Adobe After Effects Expressions Link shape to another one linked to a text
  • Link shape to another one linked to a text
    Posted by Clement Dubois on August 16, 2021 at 1:22 pm
    Hi, I surely do it wrong but I’m editing a text message like in social networks.
    I want it automatic so I already linked a text box (red shape) to my text layer but I want add a triangle to it (white shape).
    The idea is to lock the triangle to the bottom of the rectangle, but if I update my text the triangle is shifting.
    (Please pardon my poor English level)
    Clement Dubois replied 5 years, 1 month ago 2 Members · 2 Replies
  • Andrei Popa
    August 17, 2021 at 11:50 am
    I think you can add this expression to the position of your rectangle:
    s = content("Rectangle 1").content("Rectangle Path 1").size;
    [s[0]/2,-s[1]/2]
    You can take the first variable by pick-whiping the size property of the rectangle. Mind that this is not the layer position, but the one of the rectangle. Now if you make your rectangle bigger/smaller, the bottom left position will be the same.
  • Clement Dubois
    August 17, 2021 at 2:17 pm
    <div>Thanks for your reply.</div><div>
    I tried the expression but it didn’t work. But I solved it !
    I have 3 layers, 1 for the text, 1 for the rectangle and a last one for the triangle.
    Both size et position of the rectangle (path not layer) are linked to the text.
    What I did is type this in the position of the triangle (path not layer) and it worked !
    p=thisComp.layer(“My Text Layer”).sourceRectAtTime();
    w=p.width;
    h=p.height;
    l=p.left;
    t=p.top;
    [l,h+t]
