Activity › Forums › Adobe After Effects › Link Playheads between 2 timelines.
  • Link Playheads between 2 timelines.
    Posted by Dustin Bowser on April 22, 2009 at 12:21 am
    I use After Effects as a finishing tool in my RED workflow, and do all my final color correction shot by shot. There are times when I need to make an edit change, and I have to reimport my timeline to add all the effects to my new edit. What I usually do is open up both After Effects Timelines at the same time so I can compare clip by clip and see what effects need be copied. It would be great if there was some way I could link the relative position of the playhead position, so when I scroll the playhead of one timeline it moves the playhead of my other timeline accordingly. Does that make sense? Any ideas?
    Jason Brown replied 17 years, 5 months ago 2 Members · 1 Reply
  • Jason Brown
    April 22, 2009 at 3:54 am
    If you relate the comps by placing one in the other and have *synchronize time of related comps* in your preference dialogue box set…that should work.
    -Jason
