Activity Forums Adobe Premiere Pro link media
  • link media
    Posted by Zazismith on February 6, 2007 at 9:54 pm
    I digitized all of my video (from three tapes) into a project. For some reason, everytime I get out of the project and back in the media is not linked. It reads media offline. Is there a reason why this is doing this? Also, is there a way to link it all at once instead of each clip individually. I’ve been tempted to delete them all and re-digitize everything.
    Vince Becquiot replied 19 years, 6 months ago 3 Members · 4 Replies
  • Vince Becquiot
    February 6, 2007 at 10:59 pm
    If you are keeping your media on a network or an external HD, that may be the issue. Once you have all the media linked up, use the project manager and select “copy to a new location”, see if that solves it.
    Cheers,
    Vince
  • Aanarav Sareen
    February 7, 2007 at 5:41 pm
    Where is this media being stored? Make sure that the drive letter is not changing.
    Aanarav Sareen
    premiere@asvideoproductions.com
    https://www.asvideoproductions.com/techtalk
  • Zazismith
    February 8, 2007 at 4:31 pm
    It is in an external hard drive. I will try your suggestion. Do I have to re-link the media one clip at a time. That will take forever.
    Thanks for your help
  • Vince Becquiot
    February 10, 2007 at 11:07 pm
    As Aanarav mentioned, go to the drive properties and change the letter to the one that was used in the original project. You may have to try a couple of them if you are not sure what it was.
    Vince
