Activity Forums Apple Motion Link Behavior
  • Link Behavior
    Posted by Tom Fox on February 27, 2014 at 12:05 pm
    OK, so the answer to this question may be that I am barking up the wrong tree and that the link behaviour is not the way to go….
    In the image below I want to be able to move “a” and I want the line linking it to move with it (à la mind map.) The link behaviour will simply move the entire object (the line in this case) whereas I am looking for a solution (which may not exist) that would bend and stretch that line. Where only one anchor point of the line would be linked to “a”
    This is more for workflow purposes than anything else, as I have a bunch of mind maps to animate…
    Tom Fox replied 12 years, 6 months ago 2 Members · 2 Replies
  • Simon Ubsdell
    February 27, 2014 at 12:45 pm
    You’re right that linking isn’t going to do the job for you here.
    You need to use the Track Points behavior on the line.
    Simon Ubsdell
    http://www.tokyo-uk.com
  • Tom Fox
    March 16, 2014 at 9:00 pm
    Thanks Simon,
    That very helpfully put me on the right track and I see now that I very rudely failed to thank you.
    Thank you,
    T
