link a slider to Y scale and assign a specific value to represent 100% y scale
Hello creativecow members,
I am new here on this community, and it very resourceful and helpfull. I am facing an issue with After effect expressions because I am a beginner in using expressions.
I am working on chart graphs and I wanted to animate the source text according to the scale of the Y value of the shape, the issue is once I link the source text to the slider controller and I assign then the Y scale value to the slider, the text source become eventually 100 as max of the scale but instead of that I want to show a real value like : the max Y scale value (100) represent for example 2.3 but I didn’t find a way to do that but subtracting the difference from the output value
y = thisComp.layer(“57%”).effect(“Slider Control”)(“Slider”);
[100, y-43]Here is what I would like to explain:
TextSource= X Value
For Max_Slider_Control_Value= (X value)
then Shape_Y_Scale = 100%For Min_Slider_Control_Value= (X value)
then Shape_Y_Scale = 0%So when the scale in this is at 100 it will show 57 but when the slider is at 0 the source text becomes -43.
I hope I could explain the problem clearly and some one can help me on this.
Thank you!
y = thisComp.layer("57%").effect("Slider Control")("Slider");
[100, y-43]
