Activity Forums VEGAS Pro Lines on rendered video in Sony Vegas 11 (trial version)
  • Lines on rendered video in Sony Vegas 11 (trial version)
    Posted by John Ezekiel on March 1, 2012 at 1:51 am
    Hi, i’ve been making a video presentation for my school project using a trial version of Sony Vegas 11. When I rendered my video, horizontal lines appear. I’ve read a lot of forums and most of them say it’s something about “deinterlacing”. I’ve follow most of the advices such as setting the field order to -> none (progressive scan) and the deinterlace method to -> blend/interpolate fields but still the lines won’t disappear which makes me really frustrated. Please help me
    John Bean replied 14 years, 6 months ago 3 Members · 2 Replies
  • John Bolton
    March 1, 2012 at 8:39 am
    Hi John, Not knowing what your source material is you could try and Tick the Reduce Interlace Flicker box which is found by Right mouse click on the video material on the time line, then select Properties and in Video Event you will see the Tick box. If this does not sort it then more information will be require about the Source material and all project settings, etc
    John
  • John Bean
    March 1, 2012 at 7:43 pm
    Verify that Vegas interpreted your source video clips correctly!
    It doesn’t matter what your PROJECT SETTINGS are, if Vegas does not interpret your source video clips correctly, you will always end up with a mess-up render.
    Some times Vegas gets it wrong, especially on scan-type. If your video is LOWER FIELD interlaced, but Vegas interprets your video as UPPER FIELD or PROGRESSIVE (None), then you are going to have issues.
    So check your source video clip’s MEDIA PROPERTIES. Right-click it and click “Properties”. Verify that Vegas has the right values for:
    1. SCAN TYPE
    2. FRAME RATE
    See this thread: https://forums.creativecow.net/readpost/24/945203
