Activity Forums Apple Final Cut Pro Legacy lines on my burned dvd
  • lines on my burned dvd
    Posted by Kimberly Shane on October 1, 2008 at 5:51 am
    Hi!
    I shot a wedding in 720x480p on my Sony PMWex1 and when burned onto DVD you can see lines through the clips when I am panning and when people are just moving! Is this because of my sequence preset? FCP4 asks to set the sequence to the capture preset so of course I said yes, should I? Can I fix this by changing a format when exporting?
    I use a MacPro 2.8 G….
    Thank you so much!
    Kimberly Shane replied 17 years, 12 months ago 3 Members · 3 Replies
  • David Roth weiss
    October 1, 2008 at 6:20 am
    [Kimberly Shane] “when burned onto DVD you can see lines through the clips when I am panning and when people are just moving!”
    How are you monitoring the DVD? On your computer monitor, or on a TV with a DVD set top player?
    David Roth Weiss
    Director/Editor
    David Weiss Productions, Inc.
    Los Angeles
    A forum host of Creative COW’s Apple Final Cut Pro, Business & Marketing, and Indie Film & Documentary forums.
  • Stuart Simpson
    October 1, 2008 at 11:14 am
    [Kimberly Shane] “FCP4 asks to set the sequence to the capture preset so of course I said yes, should I?”
    I think you mean Final Cut Pro 6 here…
    Anyway, as for the problem it sounds like incorrect field order to me. Make sure your encode field setting matches the field order of your footage.
    -Simmie
    4 MacPros – Kona 3 & Kona LH
    2 G5s – Kona LH
    xbox360, Wii, PSP, PS2
    https://www.speak.co.uk
  • Kimberly Shane
    October 1, 2008 at 4:15 pm
    I am monitoring it on a dvd player. I shot it in 30p at 720×480 and used the same capture preset as the video. I made the dvd in 30p and thats the result I get. Its not like this is the first time I’ve done this but this is the first time I’ve used Encore for my authoring.
    But, I will try the field encode setting, thanks for your help.
    Kim
