Activity › Forums › Adobe After Effects › Lines Creator?
  • Lines Creator?
    Posted by Nick Van horn on August 23, 2016 at 9:54 pm
    Can some one identify the line effect used to create and transition between shapes used in this video? https://youtu.be/Z6nQ8zD8qOw I was wondering if it could be done with Lines Creator or if there is another effect,script or plugin that can generate the effect?
    Thank you!
    Tudor “ted” jelescu replied 10 years, 1 month ago 2 Members · 2 Replies
  • Nick Van horn
    August 24, 2016 at 3:42 am
    Sorry about the repeat.
  • Tudor “ted” jelescu
    August 24, 2016 at 6:37 am
    I am not aware of a plugin that can do the complex transitions in your example. Most likely it was done using well planned elements and animated masks or wipes.
    Tudor \”Ted\” Jelescu
    Senior VFX Artist
