Activity Forums Adobe Illustrator Lines appear when using patterns
  • Lines appear when using patterns
    Posted by Charles Roberts on July 9, 2012 at 8:56 pm
    Hi – I’m hoping someone can help me..
    When I fill a shape with a pattern (in this case ‘smooth wave’) very fine lines appear in the fill.
    I guess they might be created between tiles (?).
    I’ve uploaded a screen grab. The lines are VERY fine, but do print out unfortunately.
    Anyone know what I can to to lose them?
    Thank you in advance,
    Charles
    Vincent Rosati replied 14 years, 1 month ago 2 Members · 1 Reply
  • Vincent Rosati
    July 9, 2012 at 11:29 pm
    Typically this is just a screen rendering issue, but you point out that you also see the issue in the print.
    Most likely, you’ll need to edit or possibly rebuild the pattern.
    Vince
    *Please remember to Rate our replies or check Solution if solved. If you get a good idea from the post, consider clicking the Kudos option.
