Liner notes from Nikon D800 into BMD Hyperdeck 2
So far,
Surprise number one, video direct is getting sent at 29.97 fps, even while set to 23.97 fps in camera? That’s a nuance which may be related to the capture device as I’m bridging with Mac Drive software.
I don’t want to spend $4,800 on the CineForm based deck, at least not yet.
29.97 should also should make video folks migrating over happy, as some dislike the 24fps “filmic” look.
I’ll have to sleuth this with Nikon, perhaps drive down and talk to the horses mouth about the why’s, and if an upgrade firmware can fix that, or see what BMD says about AVID codec and the HDMI specs from Nikon.
Surprise number two, “zoom” in real time live view buttons work, in direct out but not in SD/CF capture, something others might be aware of but a pleasant surprise to me.
That means the image in video is being cropped during capture, very convenient for planning to cut a CU shot, or pull shot,refocus if need be or just let it ride, juxtaposed to sweet spot of the lens, framing etc, without resetting the fn button for crop which requires a start stop of live view. The fn only activates FX or DX in video mode as we know.
How cool is that for macro video? Dunno’, many DSLR folks do not shoot video, but it sounds cool, I may try it on the Bird of Paradise in the portico.
From Premier Pro’s time line after drag and drop from the SSD dock, using DNxHD codec AFAICT, recording to Black Magic Hyper Deck 2, this is the read out:
File Path: C:Yadda, and more yadda
Type: QuickTime Movie
File Size: 19.2 GB
Image Size: 1920 x 1080
Pixel Depth: 24
Frame Rate: 29.97
Source Audio Format: 48000 Hz – 24 bit – Mono
Project Audio Format: 48000 Hz – 32 bit floating point – Mono
Total Duration: 00:02:02:18
Average Data Rate: 160.2 MB / second
Pixel Aspect Ratio: 1.0QuickTime Details:
Movie contains 1 video track(s), 1 audio track(s) and 0 timecode track(s).Video:
There are 3678 frames with a duration of 1/29.97th.Video track 1:
Duration is 0:02:02:22
Average frame rate is 29.98 fpsVideo track 1 contains 1 type(s) of video data:
Video data block #1:
Frame Size = 1920 x 1080
Compressor = Uncompressed 10-bit 4:2:2
Quality = Most (5.00)Audio:
Audio track 1 contains 1 type(s) of audio data:Audio data block #1:
Format = 24 bit – Stereo
Rate = 48000 Hz
Compressor = lpcmSo it’s 10 BIT 4.2.2 captured on the Hyper Deck 2 according to Adobe.
Looks like a pleasant challenge regardless, very insignificant color noise and PC screen moire as a light show. (The watch is propped against the LCD)
By no means is it daylight as the sun rises onto Zaberiskie Point in Death Valley, just high ISO 3200 f/8, 24-70 cranked all the way out at minimum distance (12″ or so) with one clear 25w music stand oblong bulb overhead, hand held at close range, as my old film scoring stop watch spins the hands.
Uncompressed and impressed!
Have fun,
Rob
